Re: Rough Idle on Farmall Cub...
Posted by Bob M on April 22, 2001 at 07:01:14 from (66.66.72.246):
In Reply to: Rough Idle on Farmall Cub... posted by Kevin Hunter on April 21, 2001 at 10:09:38:
Kevin - Could be a vacuum leak like Phil suggests, or could also be a clogged idle circuit in the carburetor. If you find no vacuum leak, suggest tearing down the carb again and carefully cleaning out the idle circuit passages with a fine wire. Pay special attention to the idle bleed port (there may be two ports...) drilled thru the side of the venturi in the plane of the throttle plate - the openings are very small and easily plugged. Use compressed air to blow thru each passage to insure it's clear before reassembling the carb. Note - If you just put a rebuild kit into the carbe, it's OK to reuse the new gaskets.... Good luck!
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
