Re: farmall A radiator fan leaks oil
Posted by Dave G on April 22, 2001 at 07:32:27 from (158.252.165.218):
In Reply to: farmall A radiator fan leaks oil posted by Tom Owens on April 21, 2001 at 19:00:00:
Haas has some good advice on this. If you still can't get the leak below the level you want then I would buy a new one. The new ones have sealed ball bearings instead of bushings/oil design. In my opionion the new ones are better.
Post A Followup
: Re: Re: farmall A radiator fan leaks oil
