Re: H Bolster questions....
Posted by The Undertaker on April 22, 2001 at 13:20:52 from (64.40.66.233):
In Reply to: H Bolster questions.... posted by Doug D on April 22, 2001 at 12:54:37:
Doug: Sure! If you are installing the upper seal, then I suggest you inspect both upper and lower bushings while at it. You're lucky if only the seal is gone and exceptionally so. Be sure check pivot shaft bearing. So happens mine was worn sufficient to have caused the the pivot shaft to bear up against the boss on bottom of upper bolster and cut into it. Had to add a spacer to compensate for loss of metal. The entire weight of tractor front end rests on that ball bearing. When you drop the pivot shaft out it will tell you a lot! Careful to secure the tractor well when removing the lower bolster assembly. I had built a crib, much like a saw horse to go under the rails, but ended up taking off the bolster, because of the shape it was in and had to bench press new bushings in it. Good luck, "TU"
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
