Re: Re: Removing M clutch shaft?
Posted by Lowell Davis on April 22, 2001 at 16:45:17 from (207.206.16.228):
In Reply to: Re: Removing M clutch shaft? posted by Haas on April 22, 2001 at 14:51:43:
Thanks for the tip Haas -
I already have the clutch compressed with the three cap screws, and the driven member spins freely. Tomorrow I'll try turning and tilting the shaft - so far I was just pulling straight out.
I even removed the other three screws that hold the clutch to the flywheel and tried to pull the whole clutch, but it's not budging.
Post A Followup
: Re: Re: Re: Removing M clutch shaft?
