Re: M and B questions
Posted by gene b on April 24, 2001 at 18:10:01 from (63.15.134.76):
In Reply to: M and B questions posted by Bryon on April 24, 2001 at 13:24:03:
the timing marks for the B are on the flywheel but you cant put the mag in on no1 fire as is is on the spring loaded impulse take out no 2 plug then turn it over a little after compression then before no1 is on compression you can put the mag in and line up the timing mark on the flywheel the the rotor should be lined up on no1 the cap is marked for no1 wire to double check turn motor with crank over one rev and double check for no pos to fire ther is no way to advance or retard the mags
Post A Followup
: Re: Re: M and B questions
