Re: Re: Farmall H_Lift-all
Posted by JLE on April 25, 2001 at 04:35:30 from (12.76.70.120):
In Reply to: Re: Farmall H_Lift-all posted by Doc on April 24, 2001 at 20:52:15:
Delay action was caused by two different size cylinders, a 3" lifting easier then a 21/2". The delay in dropping is the two front ports have one ball on a seat for return, and the rear on left has same, when you push leaver forward you release one ball, push on down and you release the other ball.
Post A Followup
: Re: Re: Re: Farmall H_Lift-all
