Re: Re: Re: Farmall H_Lift-all
Posted by Doc....confused on April 26, 2001 at 01:10:29 from (204.73.55.10):
In Reply to: Re: Re: Farmall H_Lift-all posted by JLE on April 25, 2001 at 04:35:30:
All I have read prior to seeing this response, here and elsewhere, I was under the impression the delay was in the pump. I just had my M belly pump apart, found no provision for a delay. I checked further in the I&T manual and that shows what appears to ba an adapter that goes on the outlet with a check valve and there is an explaination of the different pressures involved. the pressures listed are in the 400 psi range so it must be for older pumps, did the newer 800 psi pumps use something else? Thanks. Doc.
Post A Followup
: Re: Re: Re: Re: Farmall H_Lift-all
