Re: fire, bad voltage regulator?
Posted by gene b on April 25, 2001 at 05:41:27 from (63.42.174.125):
In Reply to: fire, bad voltage regulator? posted by John on April 25, 2001 at 05:35:28:
no you had a unfused line touching ground if the reg goes bonkers it will take out the gen
Post A Followup
: Re: Re: fire, bad voltage regulator?
