Re: 1942 'Old Rusty' Farmall H Update
Posted by Red Raider on April 26, 2001 at 19:43:33 from (208.188.22.187):
In Reply to: 1942 'Old Rusty' Farmall H Update posted by The Red on April 26, 2001 at 15:31:08:
This method requires disconnecting one or more rods from the crank. Disconnect one, set a hydraulic jack below with an extension to reach the piston, and slowly raise the jack. The chances are better breaking free one at a time rather than fighting three. Even if the extension punches through the piston, you could use the sawzall to finish the job. Don't get the top of the connecting rod.
Post A Followup
: Re: Re: 1942 'Old Rusty' Farmall H Update
