Re: Breaking Hydraulic Pump Shafts
Posted by kurt on April 28, 2001 at 08:01:31 from (63.212.148.221):
In Reply to: Breaking Hydraulic Pump Shafts posted by Mike on April 28, 2001 at 06:25:06:
It sounds to me like the hydraulic system
is being deadheaded, The pump outlet is being
closed and then causing the shaft to twist off.
You probably have a stuck relief valve, Try
loosening the fitting from the ppump outlet
and see if hydraulic fluid squirts out. Make
sure you can turn the hydraulic pump shaft by
hand.
Post A Followup
: Re: Re: Breaking Hydraulic Pump Shafts
