Farmall Tractors Discussion Board
Re: 140 cultivator bolts
Posted by Daniel on February 09, 1999 at 17:21:03:
In Reply to: 140 cultivator bolts posted by Patrick Sharkey on February 09, 1999 at 16:07:14:
When I had some work done on my steering box, a local welding shop said they had seen them rethreaded. Also on mine two of the bolts have nuts on them that you tighten down against the top of the threaded hole to lock the bolts. I imagine all four were like this originally, but were lost over the years and replaced. The shop said they could weld up the bars on the cultivators and grind them square so they would tighten up. Hope this helps.
Post a Followup
: Re: Re: 140 cultivator bolts
