Re: farmall cub magneto
Posted by p on May 02, 2001 at 08:26:36 from (131.210.22.106):
In Reply to: farmall cub magneto posted by Todd Hatfield on May 02, 2001 at 07:12:09:
You have discovered the impulse of the magneto. Yes! that is supposed to happen. The magneto is different from a distributor in that the magneto generates its own electricity to run. The distributor only "distributes" the electricity from another source.
The Magneto does not turn fast enough when the engine is spun for starting, so the impulse fixes that. The little arms stop the rotation of the magneto for a moment allow the springs to wind up. When the magneto turns enough to fully wind the spring, the impulse trips, which allows the magneto to turn very fast and thus create enough of an electrical current to produce a spark. If you take off the distributor cap and turn over the engine you will see this process. DON't touch anything! That shock is strong!
Brng the cub back to Top Dead Center (TDC) on #1 cylinder. Reinstall the magneto so the rotor is pointing at the number #1 cylinder. Retard the magneto timing by turning it counter-clockwise (push the top towards the cylinder head). Rotate the engine to TDC at number 1 again. slowly turn the magneto clockwise(pull towards you) until it clicks. THe timing is now set.
When the engine is running the magneto is turning fast enough and the impulse is not actuated.
hope this helps. a good manual will also help. Let me know if this helps and please feel free to ask for more.....p
Post A Followup
: Re: Re: farmall cub magneto
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
