Re: IH Cub Low boy - gear oil leaking from shifting fork cup
Posted by Phlogiston on May 05, 2001 at 08:35:45 from (63.26.0.37):
In Reply to: IH Cub Low boy - gear oil leaking from shifting fork cup posted by Jeff Killin on May 04, 2001 at 20:37:54:
Jeff, are you sure you have the proper amount of oil in the transmission? Sounds to me like you are way over-filled. If water has entered the transmission, it will sit at the bottom and the Hy-Tran will float on top and that is what will come out the shifter. I suggest draining the transmission, and refilling with the correct amount of Hy-tran. A kerosene flush would help too. Is the tractor kept outside?
Post A Followup
: Re: Re: IH Cub Low boy - gear oil leaking from shifting fork cup
