Re: Re: IH Cub Low boy - gear oil leaking from shifting fork cup
Posted by Jeff Killin on May 05, 2001 at 11:37:08 from (208.177.204.134):
In Reply to: Re: IH Cub Low boy - gear oil leaking from shifting fork cup posted by Phlogiston on May 05, 2001 at 08:35:45:
No, always been kept indoors. Didn't start leaking until last summer. no leaks 4 years prior. Almost acts as if the trasmission is picking up pressure, forcing the gear oil up and out. Once pressure relieved, it doesn't expell any more oil for about an hour or so.
Post A Followup
: Re: Re: Re: IH Cub Low boy - gear oil leaking from shifting fork cup
