Re: HELP!...I've got a wiring mess I'm charged up about! (ha, ha)
Posted by Bob M on May 05, 2001 at 11:38:31 from (66.66.72.246):
In Reply to: HELP!...I've got a wiring mess I'm charged up about! (ha, ha) posted by Thor on May 05, 2001 at 11:09:04:
Hey Thor - here's a few things to get you started: 1 - The two unused terminals (#1 and #2) on the alternator. Are the spade terminals in line like this: - -, or are they parallel like this | |? If they are inline it says you've got an internally regulated alternator. And the rubber plug indicates it's probably a so-called "one wire" unit - the plug is there to cover up the two unused terminals. If that's indeed the case, the alternator should charge once the motor's been up to close to full RPM. Once the alternator starts charging, it'll continue to charge all the way down to idle. Regarding the voltage regulator, presuming it's for the original generator (has 4 terminals labelled B, G, F and L) you can get rid of it. 2 - A couple ways to check the coil: Look and see if it's stamped "12 volt" someplace. Or you can turn on the ignition (don't start the motor) and look at the ammeter. If the meter shows 3 or 4 amps discharge, the coil's a 12 volt. If it draws 6 amps or more, it's a 6 volt coil. Or you can feel the coil after the motor has been running for 10 - 15 minutes. If it's just slightly warm it's a 12 volt. If it gets real hot to the touch, it's 6 volt. If you find you have a 6 volt coil, stick a ballast resistor in series with the coil, or replace it with a 12 volt coil - otherwise you'll burn up the points and/or the coil. Hope this helps!
Home
| Forums
Today's Featured Article -
Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
