Re: Blowing Cub
Posted by p on May 06, 2001 at 12:47:05 from (12.33.190.5):
In Reply to: Blowing Cub posted by Terry on May 05, 2001 at 13:14:26:
Phlogiston is exactly correct, check the tube. but for your information... the motor is not sleeved and rings are a good fix if the cylinders are not too out of round. If the tractor has been sitting a buch it may just need to be run and maybe tuned up. Is it blowing blue smoke? Also, try a compression test of the cylinders. this will tell you alot.
let us know what you find...
Post A Followup
: Re: Re: Blowing Cub
