Re: BOB M. I'm just about there, but I need some more advice
Posted by Bob M on May 07, 2001 at 12:34:33 from (192.232.119.194):
In Reply to: BOB M. I'm just about there, but I need some more advice posted by Thor on May 07, 2001 at 10:33:47:
Thor - Sounds like you're almost there indeed! But here's my thoughts on where you have now: 1 - No crank when you turn the key: Presuming you've got it wired up correctly, the only possible cause is either a bad solenoid or a bad key switch. Try putting a test lamp between the key switch "S" terminal and a good ground. Now see if 12 volts appears when you turn the key to "start". If you get 12 volts, the solenoid must be bad. If you get nothing, the problem is in the key switch. 2 - The alternator must be run up to a certain RPM before it will "turn on" (begin generating current) after startup. That's why you get nothing until you run up to half throttle or so. 20 amps (or more) is normal charge rate immediately after starting. However the ammeter should taper down to 3 or 4 amps after the motor's run a few minutes - assuming the battery is good. If it does not, it means the internal regulator is not working right and you risk overcharging the battery. Hope this helps. Email me offline if you have more questions - I'll help if I can. ...Bob M
Home
| Forums
Today's Featured Article -
A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
