Re: '46 Farmall M Brakes Installation??
Posted by The Red on May 08, 2001 at 08:52:19 from (206.246.187.2):
In Reply to: '46 Farmall M Brakes Installation?? posted by Tis on May 08, 2001 at 08:13:41:
Tis I'll give you typed instructions. I don't feel like hollarun today. :)
Disconnect the brake return spring.
Then disconnect the brake rod yoke pin from the brake band lever arm.
Remove the 5 hex head bolts that holds the cover on. If your lucky, it will slide off. Inspect the band and check to see if you have 90W leaking around the drum and hollar back.
If you have a stuck cover, we'll have to walk you through that procedure. Brake removal can be a real pain at times.
Post A Followup
: Re: Re: '46 Farmall M Brakes Installation??
