Re: Transmission Differential Oil
Posted by Haas on May 08, 2001 at 18:21:09 from (64.12.102.22):
In Reply to: Transmission Differential Oil posted by Jesse on May 08, 2001 at 18:15:25:
Use either 90 wt gear oil or you can use HyTran(Tractor Fluid) from the IH dealer. You can buy it in 5 gallon buckets. It takes 13 gallons. If you have water in there, be sure to drain the belt pulley case too. YOu have to take the bolts loose that hold the shaft in and pull the shaft and the flange out a little to let it drain. When you refill, put a pint or so in the fill hole on the top of the pulley housing for the initial lube of the pulley bearings. The pulley gears and bearing are lubed from the transmission, but there is a small reservoir of lube up there that has no drain and water tends to accumulate there.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
