Re: H carb adjustments..does this sound right.
Posted by The Red on May 12, 2001 at 10:06:32 from (12.75.196.91):
In Reply to: H carb adjustments..does this sound right. posted by Doug D on May 12, 2001 at 09:59:26:
Doug lean your high speed down another 1/4 turn or so. If you have new packing material installed for the high speed needle, it sounds like you need to tighten down the packing nut a tad more. Keep a screwdriver on your needle while you tighten the nut so you don't mess up your mixture setting. I am not sure what you mean by "discharge nozzle screw head".
Post A Followup
: Re: Re: H carb adjustments..does this sound right.
