Re: power loss on 140 tractor
Posted by Curt Cooke on May 15, 2001 at 06:17:42 from (12.150.39.226):
In Reply to: power loss on 140 tractor posted by Mark Calderone on May 14, 2001 at 18:29:05:
Mark, as Daniel states, you need to verify that you have a good flow of fuel to and through that carb. Pull the drain plug out of the bottom of the carb and with the fuel turned on, determine that fuel is flowing freely through it. You'll get an initial gush of fuel as the float bowl empties, what happens after that is key, there needs to be adequate flow. Now, usually partial choking compensates for either vacuum leaks or poor fuel. Lastly, assuming fuel has been ruled out, try an inexpensive experiment - replace the ignition coil (assuming a battery ignition unit).
Good Luck,
Curt
Post A Followup
: Re: Re: power loss on 140 tractor
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
