Re: What is the purpose of a solenoid on the starter?
Posted by The Red on May 15, 2001 at 15:52:46 from (12.75.196.104):
In Reply to: What is the purpose of a solenoid on the starter? posted by Jacob on May 15, 2001 at 15:49:44:
The solenoid is basically a seondary starter button. When you turn the key to the crank positon, the solenoid is activated. A plate inside the solenoid drops doen on two posts so current will run to the starter. When you let off the key, a spring pulls the plate away from the posts so the starter quits cranking.
Post A Followup
: Re: Re: What is the purpose of a solenoid on the starter?
