Re: Re: Re: Re: CUB 154 POWER LOSS
Posted by MIKE JOHNSON on May 16, 2001 at 05:42:57 from (204.155.48.27):
In Reply to: Re: Re: Re: CUB 154 POWER LOSS posted by John on May 15, 2001 at 15:02:37:
I replaced the valves and springs, installed new head gaskets. The pistons, rings, and cylinder walls looked great. I should of replaced the rings anyway, but they appeared to be in excellent condition. The valves were set at .015, but I have recently seen on this forum suggestions for them to be set at .013. What is the correct specs.? And if .013 is correct, will the difference affect compression?
Post A Followup
: Re: Re: Re: Re: Re: CUB 154 POWER LOSS
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
