Re: Farmall H Carburetor
Posted by The Undertaker on May 16, 2001 at 06:36:13 from (64.40.66.120):
In Reply to: Farmall H Carburetor posted by Phil R on May 15, 2001 at 16:08:16:
Phil:
Is it possible when reinstalling carb and connecting up the governor control shaft housing that throttle shaft in housing did not engage properly with the butterfly shaft of carb? If you got gas, air and spark, all the ingredients you need are there. Simply a matter of putting them all together in right proportion at proper time, and boy o'boy, that can be a test of a man's endurance?
"TU"
Post A Followup
: Re: Re: Farmall H Carburetor
