Re: Re: Cub Hydraulic System
Posted by Chris on May 18, 2001 at 13:36:44 from (12.13.32.201):
In Reply to: Re: Cub Hydraulic System posted by Tom W on May 18, 2001 at 13:15:55:
Do I bolt it in the up or down position or in the middle. I should not matter where the touch control lever it because it is always in neutral. Why does the hydraulic system make so much noise when I have the loader pluged in, Is it because the air is not getting out of the resevoir?
Post A Followup
: Re: Re: Re: Cub Hydraulic System
