Re: live hyd on H
Posted by speed bump on May 18, 2001 at 20:48:04 from (132.158.129.139):
In Reply to: live hyd on H posted by budaa on May 18, 2001 at 06:22:14:
check your pressure with a gauge , should be 750 to 850 pounds with the belly pump. I have the same hitch and it could lift my truck . it has 3 by 8 cylinders. I suspect your pump isnt puttin out enough pressure. speed bump
Post A Followup
: Re: Re: live hyd on H
