Re: CUB axel extension removal HELLp!
Posted by Harold Hubbard on May 19, 2001 at 05:10:02 from (209.198.82.187):
In Reply to: CUB axel extension removal HELLp! posted by Sharkey on May 18, 2001 at 07:05:46:
The piece is junk, right? Get a good sawzall, cut the spindle end off the tube, then split the tube until you can squeeze or hammer it closed a little bit. Check with your "new" piece to make sure you can get a blade that will reach to the end of it. You might have to split it in more than one place, then pull out the pieces. If you are real crafty with a cutting torch, you can do it that way, but you can also trash the outside tube if you're not real careful. You would need a torch with a straight head, not the usual right angle.
Post A Followup
: Re: Re: CUB axel extension removal HELLp!
