Re: Re: M Hydraulic Pump doesn't work
Posted by Charlie on May 19, 2001 at 15:58:31 from (209.130.133.10):
In Reply to: Re: M Hydraulic Pump doesn't work posted by The Red on May 19, 2001 at 10:37:49:
You can't get the pump back into the tractor without lining up the couplings but if the cover was off the pump its very possible the lever is not connected inside properly - had it happen to me.
Post A Followup
: Re: Re: Re: M Hydraulic Pump doesn't work
