Re: Hydraulic Plumbing
Posted by gene b on May 20, 2001 at 03:38:05 from (63.15.137.160):
In Reply to: Hydraulic Plumbing posted by 1PWRFULH on May 19, 2001 at 20:14:38:
easiiest and best way would have the loader on a circut by itself but a ball valve will work ok as you dont need both at the same time the left rear outlet on the original was a delayed for the rear imps you can run the loader out of one port then a tee to go to the cycls use this set up on my B when want to use blade on back just shut off the line going to the cycls on the loader this also locks the loader in position can also use two way on the blade but all it does is raise up the B nice way to change tires
Post A Followup
: Re: Re: Hydraulic Plumbing
