Re: Re: Hydraulic Plumbing
Posted by Paul M. on May 21, 2001 at 15:19:09 from (152.163.213.176):
In Reply to: Re: Hydraulic Plumbing posted by gene b on May 20, 2001 at 03:38:05:
I have the setup you're thinking about on my 47 H
with 3 ball valves - 2 for the loader on the 2 forward outlets and 1 for the 3 pt on the rear outlet. It works fine, but there's gotta be a better way. Like Gene said, the rear hole is a delayed lift - it kind of works a little different from the fronts. Going up seems normal, but down is all or nothing. Makes it a pain to adjust the height of the blade. Also I would like to use a different valve so I wouldn't have to jump off the tractor to switch from loader to 3 pt.
Post A Followup
: Re: Re: Re: Hydraulic Plumbing
