Re: 59 560 Gas model won't start
Posted by Fudd on May 20, 2001 at 07:06:55 from (209.244.76.46):
In Reply to: 59 560 Gas model won't start posted by Vincent on May 20, 2001 at 06:39:52:
Sounds like you might have a ground problem. Just to check, run a cable right from your battery negative to the starter mounting bolt making sure all the connections are clean. Also do a voltage test starting at the starter to make sure the voltage is staying up when you crank it. Good luck.
Post A Followup
: Re: Re: 59 560 Gas model won't start
