Re: Re: 59 560 Gas model won't start
Posted by Vincent on May 21, 2001 at 16:06:48 from (38.27.1.215):
In Reply to: Re: 59 560 Gas model won't start posted by Fudd on May 20, 2001 at 07:06:55:
Am going to pull the starter off, as well as the battery, after trying relocating the negative cable. As much cleaning of everything on the cables, and where they mount, I figured I had a good ground. Am going to check out the starter again at work, as well as the battery, to assure neither of those are the problem.
On the first post response, how much is the book, and is it a service manual?
Post A Followup
: Re: Re: Re: 59 560 Gas model won't start
