Re: Pull front pulley on Super A
Posted by Kent on May 21, 2001 at 15:15:24 from (199.120.115.98):
In Reply to: Pull front pulley on Super A posted by marvin on May 21, 2001 at 14:48:54:
Marvin,
1. Check for a threaded hole in the end of your crankshaft. Drill a small indentation in the center of the head of a bolt and screw the bolt into the end of the crankshaft.
2. Do not try pulling on the outside edge of the pulley. Often the pulley will break. Use a bearing separator so you are pulling on the back side of the pulley hub.
3. Slightly heat the pulley evenly. It doesn't need to be hot. Just a good warming will make the job easier.
When reinstalling the pulley use the threaded hole in the end of the crankshaft to pull the pulley on.
Good Luck,
Kent
Post A Followup
: Re: Re: Pull front pulley on Super A
