Re: in need of A smart person
Posted by jimmy on May 22, 2001 at 18:29:09 from (152.163.205.68):
In Reply to: in need of A smart person posted by cyborgben on May 22, 2001 at 17:30:31:
try setting those points at about .014 to .015 for mag. also check impulse on front of mag could be bad. impulse backs timing up to o degrees when cranking then advances to 14 degrees after starting. hope this helps to get you going again.
Post A Followup
: Re: Re: in need of A smart person
