Re: Re: Re: Re: about to give up - - -engine
Posted by George on May 23, 2001 at 07:37:21 from (207.75.138.38):
In Reply to: Re: Re: Re: about to give up - - -engine posted by Gene on May 22, 2001 at 20:54:33:
Gene, is this A C301 engine?
if it is you got me thinking about the Puffin noise, Is it blowing compression by the valves? did you run a compressiom check with it warm/ hot?
you can lean the carb down by installing a adjustable main jet needle off a "M"-400 or 450 this will pretty much tell you if you are having a rich mixture problem keep us posted we will stumble on the prob. eventually
Post A Followup
: Re: Re: Re: Re: Re: about to give up - - -engine
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
