Farmall Tractors Discussion Board
Re: Re: Oil pressure to cyl head
Posted by Stan(VA). on February 12, 1999 at 21:00:59:
In Reply to: Re: Oil pressure to cyl head posted by RickB. on February 12, 1999 at 14:51:55:
Thanks for all the responses. Rick I did as you suggested as the last step before posting the question. I cranked with the starter about 5-10 seconds past pressure showing on the guage while I had the whole rocker assy, sparkplugs, and the hollow stud removed. I never got oil from that passage. I hate the thought of pulling it apart again, but it makes sense that the pressure should be there quicker than this. So I will go slow and see what turns up.
Stan(VA).
Post a Followup
: Re: Re: Re: Oil pressure to cyl head
