Re: Re: Checking cam gear
Posted by SMTA on May 23, 2001 at 17:33:56 from (12.18.158.25):
In Reply to: Re: Checking cam gear posted by Bob M on May 23, 2001 at 10:46:56:
thanks a lot Bob, am hoping it isn't thge cam gear but wondering. with getting some pressure down the intake would sounbd like a valve timing thing as the valves seem to be working and set properly. Fron what you are saying souldn't be too hard to keep everything in time just aking the hydraulic pump off. Took off the distributor a while back and did the same thing, marking the point where the rotor was pointig when I removed it so I coulc put it back in the same place. Will see how it comes out. Thanks again
Post A Followup
: Re: Re: Re: Checking cam gear
