Farmall Tractors Discussion Board
Re: RE: f-20 noise
Posted by Jason on February 13, 1999 at 10:27:36:
In Reply to: RE: f-20 noise posted by brian on February 11, 1999 at 10:55:23:
I just purchased another F-20 that the engine was slightly stuck on. After breaking it loose I turned it ove by hand with the crank and heard a similar noise torwards the bottom of the engine. I started the engine and could not hear the noise. When I shut it off I cranked it again and still heard the noise. I then pulled the side covers off the engine and looked inside. The front main bearing was the color of rust and oil mixed together, kind of like when you wire brush something rusty. So I believe you are right to assume that the noise is one of the mains.
Post a Followup
: Re: Re: RE: f-20 noise
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
