Re: cub cyclinder head
Posted by George Willer on May 25, 2001 at 10:54:13 from (64.254.131.83):
In Reply to: cub cyclinder head posted by Dave F. on May 24, 2001 at 23:13:25:
As you already know, that bolt, and most others go directly into the water jacket. There is no bottom to the hole. The bolts should have a sealant...I use teflon paste. The sealant will help control corrosion too. I hope you lost the threads to corrosion and not to over-torqueing. It is easily possible for over-torqueing to break the thin webs holding the threaded part, especially #s 5, 8, and 9 and possibly 12 and 15.
A good straightedge will detect a bulge if this has happened.
Don't ask how I know that. Well...I worked on one that had been to vocational school.
Sneak up on the 45# a little at a time.
George Willer
Post A Followup
: Re: Re: cub cyclinder head
