Re: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Bob M - yup....makes sense... on May 27, 2001 at 18:26:44 from (66.66.72.246):
In Reply to: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Red Dave - Bob M. what do you think? on May 27, 2001 at 18:04:07:
Hey Red Dave -
Your logic makes sense - I think you've correctly diagnosed the root of Gene's problem!
Another way to check would be to take a voltage reading with the ignition on and the motor NOT running. Measure between the coil "+" terminal and a good ground. With the jumper in place the meter should read battery voltage (12.6 or so), and with the jumper removed about 7 volts. This would account for the weak spark since the coil wants a 12 volt input, but is only actually getting 7 volts.
Can also try running the tractor with the jumper in place - I'll bet that solves the problem. Solution then would be to install a "6 volt" coil in place of the internally resistor-equipped 12 volt coil.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
