Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Red Dave - Bob M. what do you think? on May 27, 2001 at 18:04:07 from (64.41.22.12):
In Reply to: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Gene on May 27, 2001 at 17:04:35:
Gene, I'm assuming that you have a 12 Volt negative ground system. Those readings look about like I would expect. With the switch off the jumper will not have an effect because there is no current flowing. With the switch on, without the jumper, the resistor is dropping 4.88 volts. With the jumper on the drop is about 4 volts less. To put it another way, you get about 4 more volts across the coil with the jumper on. About 8 volts across the coil with no jumper and about 12 with it. That means that you have 50% more volts on the coil primary and that relates directly to a proportional increase in secondary (high voltage side) volts. It also appears that the points were closed when you took your readings. Yes, those readings make sense to me. Red Dave
Home
| Forums
Today's Featured Article -
Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
