The octane rating is a measure of resistance to ignition, basically the higher the octane, the hotter the flash point. The higher flash point is needed with higher compression so that the fuel doesn't detonate from the heat from compression and from the walls of the chamber. The knocking you hear is actually the engine trying to run like a diesel, through compression ignition, instead of spark ignition. It's trying to kick the crank over backwards because it's firing early. I think retarding the timing can help eliminate detonation but you'd have to check up on that.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
