Fuel quality and octane level?
Posted by SDE on March 05, 2009 at 15:44:00 from (75.121.152.32):
I just read the thread about E85.
In the past, a person or two has reccommended using high ocatane fuels in the older tractors because the regular fuel of the 50s and 60s had a higher octane rating than todays reg. fuel.
What is it about an engine that will determine if you need to use regular or premimuim fuel?
Compression ratio?
Cam shaft?
Distributor timing.
These older tractor engines are not very sophicated and I don't see why they would need to be run on High octane fuels. I really am hoping to learn a few things about this.
Steve
