Farmall Tractors Discussion Board
Re: 1468 V8 ENGINE
Posted by Skip on February 20, 1999 at 09:29:28:
In Reply to: 1468 V8 ENGINE posted by JEFF on February 20, 1999 at 09:08:50:
I don't have a reason for you,other than a bad design. If you put twin turbos make sure you have a "big basket"
Post a Followup
: Re: Re: 1468 V8 ENGINE
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
