Farmall Tractors Discussion Board
Re: Re: Model A Year?
Posted by Brian McCombs on February 21, 1999 at 09:54:42:
In Reply to: Re: Model A Year? posted by Bill Sargent on February 21, 1999 at 08:46:30:
My Farmall A is a 1939, and I found the serial # stamped on the engine block. You might find one on yours if you look on the right side (as you are sitting on the seat) just below the cylindar head parting line on the uppermost right corner of the block. You should be able to find a flat spot cast into the block, with a series of numbers stamped onto it. A wire brush and some engine degreaser will probably help. Good luck
Post a Followup
: Re: Re: Re: Model A Year?
