Re: Re-installing front crank pulley on Super A
Posted by Farmer Bob on June 13, 2001 at 09:05:37 from (208.49.9.17):
In Reply to: Re-installing front crank pulley on Super A posted by marvin on June 13, 2001 at 07:37:03:
My A's crank has 1/2" NC threads and that's what I did to pull the pulley back on. Just make sure you have a hefty washer between the pulley and the nut that you'll be turning to pull the pully on straight. Also make sure the woodruff key is properly seated and aligned with the keyway on the pulley.//FB
Post A Followup
: Re: Re: Re-installing front crank pulley on Super A
