Re: Distributor on C
Posted by Steve (MD) on June 18, 2001 at 05:59:00 from (144.51.50.70):
In Reply to: Distributor on C posted by FC on June 18, 2001 at 05:15:15:
If you took your carburator apart recently, check to see if the main gasket is upside down. On the gasket I got, there is a small hole in just one side for a jet that comes up from the base of the carb. If the gasket is upside down, it will block this jet and the tractor will idle but run really bad when you try to put a load on it.
Post A Followup
: Re: Re: Distributor on C
