Distributor on C
Posted by FC on June 18, 2001 at 05:15:15 from (208.14.16.15):
I posted a message a couple weeks ago on my C that would not run without choke. As I posted carb was fine. Since then I removed dist, and found weights,springs to be rusty, and "gummed". I cleaned with PB Blaster, reoiled, set points to .020 , and put back in. Now it will run without choke, but "surges" near idle, unless I set the timing to where it seems to "labor" the engine, then it has very poor power above idle. I think I made a mistake by not replacing springs, weights while in there. I now have dist back off and am going to check local dealer today and see if they have them. Any other thoughts??
Post A Followup
: Re: Distributor on C
