Re: wiring problem---1948 Super A
Posted by The Red on June 18, 2001 at 11:28:52 from (206.246.187.2):
In Reply to: wiring problem---1948 Super A posted by william quillen on June 18, 2001 at 11:14:01:
William how many posts and how are they marked on your voltage regulator?
Is your light switch the 3 or 4 position assembly?
If you have a simple coil switch, there is no ground on it. It simply cuts the flow of electricity to the coil.
Post A Followup
: Re: Re: wiring problem---1948 Super A
