Re: Re: wiring problem---1948 Super A
Posted by william on June 18, 2001 at 13:34:08 from (209.209.188.81):
In Reply to: Re: wiring problem---1948 Super A posted by The Red on June 18, 2001 at 11:28:52:
Reg. has 4 terminals(L Bat. F and Gen.) Light switch is 3 position. The ign. switch is original. I wired L terminal of reg. to one side of Ign. switch and neg. ground of coil to other side of Ign. switch. I wired F terminal of Generator to F terminal of resistor of volt. reg. I wired A terminal of Generator to gen. of voltage reg. I wired Bat. terminal of reg. to pos. side of ammeter. I am getting a bunch of sparks. Would the pos. battery cable not properly grounded cause this. thanks
Post A Followup
: Re: Re: Re: wiring problem---1948 Super A
